Haya.H
- Joined
- May 22, 2012
- Messages
- 308
- Reaction score
- 40
- Can others edit my Photos
- Photos OK to edit
No, but it's as close as it could be. Blown out is pure white (RGB 255,255,255), or absolutely no detail whatsoever. Looking at that one closely it is very close but there is still some detail there.Yeah I noticed that as well and thats why I changed the direction she was facing. Does one side of her face look blown out though, in the second?
You can get premade diffusers for speedlights or make one yourself from a couple of layers of translucent plastic (a piece cut from white plastic milk jug works well). Tissue paper works well to, just hold it on with a couple of rubber bands.Any suggestions on which to buy or what to make?
To diffuse sunlight a piece of muslin cloth works well, or a piece of white cardboard can be used to reflect light into the shadowed areas.
I would also ask (for #2 especially) why focal length you were at. #2 looks a little wide for me. I usually don't shoot portraits with anything less than 70mm (unless I know that I'm going for the wide, more distorted effect) the reason is simply, regardless of actual body shape, a wide angle (anything wider than 70mm usually) is not flattering to their shape! Good start, and listen to the others on lighting(that was my sexy wink attempt)
Cheers,
Jed
Cheers,
Jed
I was using my 50mm f/1.8. It's all I use for portraits since its that or the 18-55 kit lens. Taking in what everyone, I will be reshooting today![]()
