unscrewed
KenC
Philadelphia
A good screw is hard to find. ;)
Not the best monitor here, but the board on the left looks a bit bright.
I'd like to see more of what's going on down on the lower right too - not sure if that makes it a distraction.
I guess what I'm trying to say is that the textures and patterns on the right are more visable and interesting
and yet the composition is overpowered by a lot of the brightness on the left side. My eyes get pulled to the
right and then they have to stop at the edge.
I'll get home later to my regular monitor and change my mind I'm sure. ;)
I agree with Sleist about the board on the left being too bright, to the point that it impacts the composition negatively (assuming that you want the eye of the viewer to wander inside). However, if you darkened the board on the left then the image might end up missing some tones. So maybe – I guess it will be a matter of experimenting – try to darken the left board just a bit and lighten the interior just a tad.
Intriguing image.
Thanks for the suggestions. I kind of liked having high brightness on one side and high contrast on the other, but apparently it doesn't work as well as I thought. I'll post another version.
Kinda agree....bright is good for me...but I'll bet there is some lost detail that could be extracted from the board. Otherwise...interesting composition. I might darken the left, and slightly boost the contrast on the rest...but that mahy justbe my monitor. There is a neat tension created by the failed screw and the perspective...cool shot. Good for a B&W as well!!
OK - here is another version. I went back to the raw file and processed it twice - once to get the board on the left darker in the mid-tones and again for everything else - and then merged the two. I ended up with a slightly different crop, but I don't think it's a significant difference.
The edit really brought the texture out in the light areas, I like it :)
I feel like there is too much of the board on the left. Also, it seems the DOF is too shallow. The screws coming out of the board on the right seem to be OOF. The focus point seems to be at the bottom. I feel I want to like it but there is something missing. I don't know where to look in the image.
I think the title should be "board"
LOL, sorry, just playing. The edit is better.
I like the substantive size and "feel" of the board on the left, and I think the darker,m shadowed area works very well BECAUSE OF the size of that board. As to the title...the shot shows what has happened to such a good degree that the title is almost unneeded. Very illustrative. The second work-up of the image is very well done.
Thanks guys! I'm grateful for the suggestions because I now see that dual raw processing was a must for this one and I had just been lazy about it the first time.
Nice Edit. I wish you could have pulled the cables away from the bottom bracket and out of the frame.
