WayneF
- Joined
- Oct 11, 2013
- Messages
- 622
- Reaction score
- 114
- Location
- Texas
- Can others edit my Photos
- Photos OK to edit
Just to be sure, that does meen that as long as the photograph is rectilinear, the green, red and blue line in the attached illustration of a photograph all cover the same amount of degrees, considering they are equally long?
The illustration is seen through the camera if you will, the blue line is the vertical angle of view, and the other lines are equally long.
Dont worry about the numbers, they are just made up.
Yes, a perfect regular lens should be linear in every direction, and at every location.
The meaning of rectilinear is to preserve straight lines. Fish eye lenses for example, don't.
However, some regular lenses, especially more extreme wide angle lenses, often have a little distortion, pincushion or barrel distortion, so that straight lines are curved a little, perhaps quite noticeably. Like the top line of a roof running across the top of the picture may be bowed or curved a little (at any frame edge, lines at bottom or edges too). That is not linear, and it would disrupt your measurements somewhat, however it is a different effect, still intended to be rectilinear, just failing a little.
It should not be seen in lenses that are not so wide angle.
