UPDATE on my speedlight stuck on my camera....
Reyna
Texas
Ok, so the feeler gauge didn't work. You can't get the pin's down due to the location of them. So, we took out the 4 screws (which you have to have a specialty tool for that you can't get at lowes or home depot) and were able to follow the directions from O|||||||O and remove it that way.
Thanks again for all your help. This forum is awesome! You guys saved me a lot of money today :)
Make sure the pin is working propperly before you put the flash back on. :sexywink:
I'm glad it worked without costing you $250!
We just got back from Chili's - right before we left I was googling it (it seems it's not an uncommon problem) - didn't have time to post before we left, trying to beat the rain, lol.. If you didn't have it fixed by the time we got back, I had a list of links ready to go. ;)
The general consensus from what I found was to remove the base and disassemble the pin assembly - so it turns out I gave the right advice. :lol:
From what I found, there also may or may not (depends on flash model - I didn't see anything about your flash specifically) be a little metal tab sticking out under the lock ring that you can use to manually lift the pin.
Drink a beer for me. :thumbup:
:cheers:
Good for you, but tell us......What caused it to be stuck on the camera?
Was the pin no longer connected to the lock lever?
