V2 LCD Viewfinder for Canon 550D 5D Mark III
Link Delight Online Shop
Official Vendor
Supporting Vendor
The LCD Viewfinder for Canon 550D 5D Mark III is consisted of Anti reflective coated 2.8X magnifying lens, Soft rubber eye cup, plastic barrel, and magnetic LCD screen mount. When mounting on LCD display of a Digital SLR, you can achieve more accurate focus and increase stability of handheld shooting. It also can be used by photographers who want to block out light while shooting in Live View mode or to inspect pictures on the LCD display.
The LCD viewfinder allows you to put your eye right up to it, similar to the way you would on a professional camcorder. It also prevents light from hitting the screen, alone making the LCD screen much more usable.
This viewfinder allows videographers to shoot outdoors under the bright sunlight which has been a huge problem as glare makes LCDscreen very difficult to use when making movies in the afternoon in sunny areas.
The Canon LCD viewfinder uses four small magnets connecting with a metal frame that using unique adhesive connects it to the camera. The power of these magnets is strong enough to hold the loupe against the frame and camera.
Specification:
Material: Plastic, Soft leather, Optical glass
Magnification: 2.8X
Frame Size: 65(W) x 45(H)mm (inside); 74(W) x 51(H)mm (outside)
Weight: 85g
Contains:
1x LCD viewfinder for Canon 550D 5D Mark III
1x Magnetic LCD Screen Mount
