viewfinder size
Charliedelta
New york
I went to the store and played with some DSLRs. Specifically, I looked at a Nikon D7000, a D600, and a Canon 1D X. Of course it's different kind of cameras and there's a ginormous amount of differences amongst them but I'm most interested in one difference. What struck me was how much bigger were the viewfinder and what I could see inside it on the 1D X.
When comparing camera specifications on a website, what tells me how big that image would be, and how do I interpret it (like a lower number is better or vice-versa, or whatever the case might be)? Is it the "viewfinder magnification"?
Does it exist something that you can put let's say on a D7000's viewfinder to see what you'd see on a 1D X? What's the name?
Please don't answer suggesting I was comparing apples and oranges, I already know that. All I'm trying to do is learning how to call a specification of the camera, and learning about equipment in general.
Thanks
The D7000 is a crop sensor camera so it's viewfinder is inherantly smaller than those on full frame cameras, in theory you could magnify it but it would still have a smaller field of view than a FF finder. The 1DX and the D600 are both full frame but the 1DX is top league wheras the D600 is (so to speak) and entry level FF camera. I've not had a go with these FF models but I'd assume that the 1DX simply has a better viewfinder than the D600.
Full frame cameras typically have larger images when you look through the viewfinder ... and it makes sense if you think about it.
The full-frame sensor is quite a bit larger. That means the mirror also needs to be larger, so the whole pentaprism view is also larger. It's one of those ease-of-use things that makes it more pleasant to work with a full frame camera.
Nikon D7000:
Frame Coverage: 100% (approx.)
Magnification : Viewfinder magnification approx. 0.94x with 50mm lens at infinity; -1.0 m[SUP]-1[/SUP]
Nikon D600:
Frame Coverage: FX (36x24)100 %
........................DX (24x16) approx 975
Magnification 0.7× (50 mm f/1.4 lens at infinity; -1.0 m[SUP]​-1[/SUP])
Canon 1DX:
Magnification : Viewfinder magnification approx. 0.76x with 50mm lens at infinity; -1.0 m[SUP]​-1[/SUP]
This information still applies to DSLR's that use mirror/prism: Understanding Viewfinders
DSLR's with Electronic View Finders are different ... and in the case of my Sony A55, the viewfinder is 1.1x and has long eye relief.
If it's got an electronic viewfinder then it's not a DSLR. ;)
Thanks for the replies.
So if I understand correctly, a full frame will have bigger viewfinder than a crop and that's the way it is. But now, I get a little confused. The link that dxqcanada suggested says that a the larger the magnification the better. Then I look at the spects attached by KmH and it looks like the smaller the better. So if I compare cameras similar cameras just by looking at their viewfinder magnification, how do I know in which one the image will look bigger?
Also, would a viewfinder magnifier helps if you get a crop to make the image in the viewfinder more like it'd be in a full frame?
Thanks again
