rickwesh
Made in DAZ Studio 4.21
Post work in Paintshop Pro Ultimate 2022 & Luminar NEO
Thank you.Some really nice work here. Only niggles I see are, there's an odd triangular shaped place on her foot (left side of frame), the highlights on the arm and knee (left side of frame) are a little hot and could use some work, and a streak/highlight on the left breast.
Position, and ratio. Placing your key to high will cause a loss of light in the eyes create overly bright highlights under the eyes, and put the eyes in shadow. Typically I want my key off the centerline just under 45 degrees. Same on my fill. Unless I'm doing clamshell lighting with a beauty dish high on center with a large reflector low angled up.light position
Wow so much information. Excellent.Position, and ratio. Placing your key to high will cause a loss of light in the eyes create overly bright highlights under the eyes, and put the eyes in shadow. Typically I want my key off the centerline just under 45 degrees. Same on my fill. Unless I'm doing clamshell lighting with a beauty dish high on center with a large reflector low angled up.
You mentioned gobos on your lights. A gobo is a modifier that shapes a light, typically creating a pattern did you mean a Modifier?
My standard 3 light setup on portraits is a 6' brolly with diffusion set to f/8 as the key, a 2x4 softbox with diffusion opposite set to f/5.6, and a kicker 7" reflector with 10 degree grid (hair) on the same side as the key, set to the same as my key. I want the key center slightly above and angled down so the center is aimed just below the hairline. This gives me a 2:1 ratio I find more pleasing than a higher ratio.
Looks like you have a good start.haven't had much hands on experience with lights. Just bought a Godox 860iii for the camera with a Xpro trigger and a small soft box for the flash. Ma
Unless its 3D work lol. Boy that would be handy though!Looks like you have a good start.
Supplemental lighting without an incident meter makes it way harder than it needs to be, and is just about impossible to set ratios. A good used meter that measures reflective and incidents can be found for around a $100.
Just remembered his name Alberto VargasReminds me of the artist who painted for Playboy Magazine. Sorry can't remember his name.
Nice shot.
Ah yes the Vargas girls.Just remembered his name Alberto Vargas
Alberto Vargas - Bing
Intelligent search from Bing makes it easier to quickly find what you’re looking for and rewards you.www.bing.com
"I hope you don't mind but my pants are in the drier."
