wanting to make my own in home studio
well i would like to be able to also have the options of mounting the shoe mount flash to a light stand if the photo called for it.
ok, but why would you not use the receivers then? how would you trigger the flash?
yes i know i will still need the triggers but they can be mounted where ever they can detect the flash right? they dont have to be mounted on the flash right?
no. the flash slides into the top of them just like it would on your camera's hotshoe.
like in this pic
ahh ok. so i have to take the flash off the mount that comes with it and put it on the trigger mount. i was gettin confused there for a minute lol
take a look at and you will see how they attach and how they work
now the person in the vid uses a sigma flash, but they all attach the same way
btw the way he is firing it using the test button........when the transmitter is attached to your cam, it will fire when you press the shutter button.
i see what you were talking about.......the pic @ b&h
got it now. the "stand" that is in that pic is NOT attached to the flash.
that stand was used to hold the flash upright so they could photograph it
ah ok ok i got it. thanks man
now ijust need to find some light stands and im good to go
it says
"Attachment Size
5/8 in stud with 1/4-20 in threaded tip" on that link i sent
it says
"Attachment Size
yes i seen that, but you will want to find out what size the trigger will accept as it will have to attach to that light stand
ok i emailed gadget infinity
