If you want a good camera for daylight flash-as-main light, or daylight fill flash, one of the lowest cost, best alternatives might be the Nikon D70 or D70s...those two cameras can shoot flash exposures at ridiculously fast shutter speeds, like 1/1000 second, which will allow you to set up a single flash later in the afternoon, and shoot a flash exposure of a skateboarder, while keeping the background (the natural light) very DARK, due to using an exposure such as f/11 at 1/1000 second. This particular "look" is used by quite a few top skateboarding photographers, many of whom use older Nikon CCD s-slr bodies simply because they allow the use of full-power flash, not FP or High Speed Synch reduced power flash, at ultra-short exposure times.
To get these ultra-high shutter speeds, the flash should be triggered with an AS-15 hotshoe to PC outlet accessory and the flash on a bracket, or using a Wein Safe Synch, or a remote trigger. The hybrid mechanical CDD shutter the D70 and D70s uses can synch flash shot at up to 1/4000 second with even exposure of the whole frame, which allows overpowering daylight to get rid of distracting backgrounds, even if you are using an ultra-wide angle lens mounted low, by making the daylight look "dark", while the closer areas are lighted up by electronic flash. This allows some very cool-looking beautiful "sunburst" shots,where the sun is rendered with beautiful star-filter like rays coming off of it. I'm sure you've seen this in the skate magazines, or the snowboarding articles, or in photos shot by board-sports pros covering the X-Games or other top events.
The look is called "overpowering daylight" with flash. Search around for it,and you will see how unique it looks.
The plus is that D70 and D70s cameras are very low-cost, around $225-$265 used, and will autofocus with AF, AF-D, and also the newer AF-i and AF-s lenses, as well as all autofocus lenses made by Tamron,Sigma,and Tokina.
