manuel87roma
- Joined
- Sep 17, 2017
- Messages
- 20
- Reaction score
- 1
- Can others edit my Photos
- Photos OK to edit
- Thread Starter 🔹
- #16
If you were to buy a new body (but on an $800 budget I suggest you do not) the body you would probably want to look at is the EOS Rebel SL2. The SL2 has the same sensor as the Canon T7i / 77D... but significantly less expensive.
However... to get background blur, what you need are:
long focal length lenses
low focal ratio lenses
close subject focusing distance... with a distant background (separate the subject from the background).
Here's a PixelPeeper link with examples:
Full-size sample photos from Canon 85mm F/1.8
Pixel Peeps indexes images uploaded to Flickr that include their EXIF data so they know what camera body, lens, exposure settings were used. They then allow you to be nit-picky about finding examples.
The filter in the link above says it has to be an example of the Canon 85mm f/1.8 lens AND it has to be on a Canon APS-C camera body AND it has to be using an aperture in the range of f/1.8 to f/2.8 (you can control all these settings in their search controls).
So these are representative examples of what other people get using that lens at low focal ratios with an APS-C sensor body.
I wouldn't worry about getting a new camera and WiFi... instead if you really want to see the results in near real-time, buy a USB tethering cable. It's basically the same as the USB cable that came with your camera... but longer. Tethering cables are usually around 15 feet long. I picked up mine on Amazon and it was less than $10 (I think it was maybe $7). This will let you leave the camera connected to the computer and you can use tethering software such that you see the images come in on the screen just a few seconds after you take the shot.
I happen to own a CamRanger ... which is a module that gives any camera WiFi... but they cost a few hundred dollars and now that many new models have built-in WiFi... I don't see the point.
Just know that RAW images are what you really want to shoot if you want control... but RAW image files are big and they take a while to transfer. To get around this, many of the WiFi systems are really converting the RAW to a JPEG and transferring the JPEG (much faster) for "review" purposes... and you can pull the true RAW across if you want it (the true RAW files are left on the memory card.) This is especially true if you use a smartphone or tablet (they don't support true RAW files).
Based on your $800 budget, buying a new lens AND buying a new camera body is going to break the budget (for any camera that would be an improvement over what you own). But ultimately the lens will make the bigger difference. If you want the blurred background... a longer focal length + low-focal-ratio lens is going to get you there mores that anything else. I'd do that first and worry about a new camera body later.
Thank you so much very good explanation. I think I’m going to keep the EOS rebel T1i for the moment and buy the lens 85mm f1.8 or even better f1.2 UMS Which it seems to be a good lense for photoshoot portrait but also full body shoots where the subject is in the full frame of the photo.
What do you think?
