mikoh4792
- Joined
- Dec 30, 2013
- Messages
- 163
- Reaction score
- 10
- Can others edit my Photos
- Photos OK to edit
- Thread Starter 🔹
- #16
Not really sure to be exact. Just dim enough where the focus assist will need to be used.
I didn't know about the assist beam on the speedlites. I will look more into those. Are these speedlites(with the assist beam) expensive?
I know the flash shouldn't be harmful, but I'm more worried about the bright light scaring some of them and causing them to move out of their poses.
In my experiences most lizards don't respond at all to flash. This might vary species to species of course, but most are totally docile and ignore it.
As for the speedlites the Canon 430 EX II has an AF assist beam as does the 580EX II (that is now out of production but is the superior model to the 430 - the 600 now replaced the 580 but the 600 is very pricey - though it has the bonus of a built in radio trigger setup).
A 430 EX 2 or a pair of them would set you well for lighting for this kind of work. The flash if mounted on-camera will have the AF assist beam which will help significantly in very dim lighting, though of course even it has its limitations.
As said above, if the lizards are docile chances are you can focus manually.
Ah I see. I will be working with mostly snakes up close, and they do seem to react more to flashes in my experience. While lizards like to "bask", most snakes when out will try to slither away and find a hiding spot.
The canon 430 ex II looks good, and isn't too pricey. I guess the 70d is back on the list against the d7100
