Poisoned Toast
- Joined
- Oct 26, 2016
- Messages
- 4
- Reaction score
- 0
- Can others edit my Photos
- Photos NOT OK to edit
Most, if not all, of those extras are pretty much garbage, (in my opinion). I suggest you start simply with a camera and lens, then then build your system slowly over time. Your system should be built based upon your photographic experience and the desires which are generated by your experience.
Wouldn't it be more expensive to get that lens later on?Getting there ... but here is starting at Ground Zero.
https://www.amazon.com/Canon-Rebel-...=UTF8&qid=1477534419&sr=1-3&keywords=canon+t5
Probably, but after you've gained some experience under your belt ... you may want a better/faster lens than what's in the bundle. Or you may want to shoot non-zoom lens, (which generally are superior optically than a zoom) ... or your experience may dictate an initial desire for a wide angle lens than a telephoto lens. Photography is as much craft as it is a science. As a craft, your hands-on experience is required to formulate and direct your future purchases.Wouldn't it be more expensive to get that lens later on?Getting there ... but here is starting at Ground Zero.
Thank you. You've been a great help. I am going to go for the 449.00 bundle with the 75-300mm lens. Will be buying it probably this weekend!Amazon has that lens for $134.49 ... so you'd lose about $84 waiting ... yeah, I would go for the bundle which includes the 75-300.
Sorry but neither, the T5 has an old sensor on it, about 7 years old, get the Nikon D3300 which cost same but offers a modern sensor, better auto focus, better low light performance, better dynamic range, more resolution, potentially can give sharper images.
As for these painless packages, stay away from them.
Get the camera with a basic kit lens and maybe add an extra telezoom lens like 55-200mm or 55-300mm and a fast prime lens like 50mm 1.8 for low light situations and portraits.
Here is a direct comparison between the 2 cameras
