Which choice?
Trever1t
San Jose, CA
Tax return time coming do I .....
Buy
70-200 f2.8 vrII (only)
or
Tokina 11-16 and 80-200 f2.8 2-ring?
I'd sell off my 70-300 f4.5-5.6 vrII (for around $500?)
or do I hunt for a 17-55mm f/2.8G ED-IF AF-S DX and sell my 16-85 f3.5-5.6vrII
:confused:
I'm leaning towards the Tokina (new) and a good but used 80-200.
What kind of photography do you do/enjoy? I wish I knew how nice the 70-200 VR II was... but I have never used it. I actually own both the Tokina 11-16 and the 80-200 2.8 and like them both very much. Sounds like you would have the bases covered if you went with the second option.
I shoot what I find interesting which has been predominantly landscapes and nature. I am moving towards portrait photography somewhat as I learn lighting and editing techniques.
From what I've read the 2-ring 80-200 f2.8 glass is almost as good as the newer 70-200 if not as fast-focusing.
I know, I was waiting to contact you after I had the $ in hand ;)
Couple of questions...
1) will I have auto-focus capability with the 80-200 on my D300s? List of cameras stops at D100?
2) can I use Teleconverters with the 80-200 without losing function?
Yes
Yes but not the Nikon as they are designed for AF-S and not backwards compatible.
Tho you can use Kenko,Sigma and Tamron's 1.4x,1.7x or 2.0x (not recommended).
My Gal "Bertha" by orb9220, on Flickr
Tamron 1.4x by orb9220, on Flickr
Makes for a great combo. But would go 1.7x would be my limit tho.
1) will I have auto-focus capability with the 80-200 on my D300s? List of cameras stops at D100??
Yes, the 80-200 has a connector for the in-body focus screw drive, which is why it has the AF (Auto Focus) designation.
I'm pretty sure you can, but not positive. The rear lens element is recessed which leads me to believe it would work fine with a teleconverter.
thanks!
You need to define exactly what your priorty style of shooting is now and will what it will be for long term. You indicated it will be a longggg time before you can invest again in expensive gear.
You are trying to upgrade everything you got and that will be tough to do and stay within your budget.
From what I read you are into landscape and nature and would like to expand on to portrait. To upgrade your landscape lens, I would strongly consider the Tokina 11-16. A sharp image taking build like a tank lens and 2.8. I would also give some consideration to the Nikon 12-24 f/4, a few hundred more than the Tokina, but a more versatile lens. I put them in that order only because of cost. If it were not for that I would put the Nikon first. Theres also the Tokina 12-24 f/4 $100 less than the 11-16 with build in lens motor. Another great landscape lens. For landscape, the f stop is not as important as it is for nature and portrait.
Sell your 70-300 for $500? You can buy a refurbished one from B&H for $350. Or buy a Nikon 55-300 f/4.5-5.6G VR for $360, new.
To settle on a portrait lens, I would buy the Nikon 85mm f/1.8D for $430 and never look back! Regarded as one of the best prime portrait lenses. Or save a little more and buy the Nikon 50mm f/1.4D for $330. ANother great portrait lens. Both of these lenses produce very sharp images even in low light.
So let's assume you settled for the Tokina 12-24 f/4 and the Nikon 50mm f/1.4D and you spent $830.00. Thinking of your budget you may have around $1200 left? I would keep the 16-85 f/3.5-5.6 for everyday up and down the street shots and sell the 70-300 and now you got enough to buy an excellent used Nikon 70-200mm f/2.8 VR1 that you will never regret purchasing. Explore all avenues and you will find one, I did.
Then you are set! Of course, somewhere down the road, you may want to pick up a Nikon teleconverter 1.7 for the 70-200 for a couple hundred or so.
Good Luck!
I wouldn't completely dismiss the single ring version of 80-200mm lens either... it's optically just as good, and just as well built, it just focuses a tad slower. But for only around $450 in great condition, it's a steal!
Unless you're shooting a lot of action/sports, it's hard to see why a tiny bit of extra focusing speed would be worth paying nearly twice as much.
