What is the correct white balance setting to use for an indoor shot with the lights on (tungsten) along with a speedlight flash on my camera with a diffuser attached (pointing at 45* upwards)?
I took a couple sample pics using all the different white balances available and I found Shade and Flash to give me the most accurate colors. Between the two I'm leaning towards Shade as being more accurate. Shade provides a bit more warmth then the flash setting does.
What do you guys/gals use as your white balance when shooting indoors in a similar situation as mine? If using a flash is it always better to set the WB to Flash? Or since I'm mixing my lighting sources would it be better setting it to something like shade?
