cynicaster
- Joined
- Feb 27, 2013
- Messages
- 756
- Reaction score
- 301
- Location
- Ontario, Canada
- Can others edit my Photos
- Photos OK to edit
Since you said “18mm lens” and your camera is the T3i, I’m assuming you’re using the 18-55 kit lens.
First thing’s first. To be blunt, f/10 makes no sense in this situation. At least, not to me. Not only does it increase the sharpness (and therefore the “prominence”
of distracting background elements, it unnecessarily strangles the stream of light coming into the camera, forcing you to use a high (noisy) ISO setting in order to get a good exposure.
You’re probably already aware of this, but I think it merits an explicit statement just in case: numerically larger f-numbers make the aperture smaller, and let in less light.
If you could go back in time and redo this exact photo, I’d suggest the following:
If you take care to be as steady as possible, the 1/125 shutter speed you mentioned should be fast enough to allow hand-holding of the camera at these focal lengths, but for a shot like this, don’t discount using a tripod with remote shutter release or 2 second timer.
Throw in some subtle additional sharpening in post (if you like), and you should get you some pretty satisfying results.
- Open up the lens to f/5.6—this is not the widest available aperture, but the widest available aperture on cheap lenses is never the best choice if sharpness is paramount. This will get you two more stops (or 4x) the light that f/10 gets you with all else being equal, which, in turn, will allow you to drop your ISO by the same two stops to a much more T3i-friendly setting of 800. Shutter speed would remain unchanged.
- Move back with your feet, and zoom the lens part way—get roughly the 35mm marker dialed in on the barrel if space in the room permits. Using kit zooms at their extremes (i.e., 18mm and 55mm in this case) is bad for sharpness as well. Try to fill most of the frame with the cat, but don’t go overboard, because it will make for a cramped photo and it will limit your cropping options later.
- Focus on the cat’s eyes, and take the shot
