Why do people in my photo's look fat?
maxa27
queensland australia
Why do people in my digital photos look fat or squatish ( No they are not fat or deformed in real life) What settings have I got wrong? How do I correct this?
Shooting with a wide angle lens can definitely contribute to this effect. Putting folks near the edges while shooting wide is even worse. Perspective also has an effect on how large people look--in general, shooting from below and tilting up a little tends to 'add weight'.
This is the first time I have tried to upload a pic so I hope this works
The other possible explanation is they are fat. I'm no twig myself, it is more apparent in images though.
Do they look fat to you when you review the images in camera, or only on your computer? Nothing looks wrong with that picture (aside from the belly shirt, cell phone camera guy...gross)
You're compressing a 3 dimensional space in to a 2 dimensional space.
And you're basically cropping out part of a scene onto a little bitty 3:2 image, which brings more attention to all aspects of a scene
If you use a focal length under 50mm, when somewhat close to the subject... it can cause distortion along the lines of "making people look fat". Even a 50mm will do it if you are too close to the subject. Telephotos (above 50mm) have the opposite effect, and are slimming (but also require that you be farther away from the subject.
You have no Exif data in the shot you posted.. so I cannot tell exactly what FL you shot this at. Just keep the 50mm rule in mind... and maybe even play with it. Take some closeups of people at 18mm... and then try the same framing at 200. It can be fun.
It could be shooting with at the wide angle end of that lens causing a distortion as others have said. I have actually had the inverse problem of taking pictures of a person and they were looking too skinny. My girlfriend is very thin and I was taking some photos of her with a strobe. When the light would cause shadows on her and then contrast enhanced in pp she became extremely skinny looking. Maybe add some local contrast to your friends, they look a bit neutral. and poof instant Jenny Craig!
anyway here's how the effect ended up working out. Not what was I going for in the shot but it exemplified the weight loss effect somewhat.
_DSC4749 1 by rhoads238, on Flickr
This is obviously less than a desirable result. It was also one that I hadn't quite expected.
I dont see the problem. At least shes not a fat white dude.
