Wide angle lens vs. Telephoto lens
joel28
Brooklyn, NY
I read that a wide angle lens pushes objects to the back. Can someone demonstrate an example?
Thanks!
Thanks!
You're referring to the depth that a wide lens gives versus the compression that a telephoto gives. Basically, with a wide lens, objects closer to the lens will appear much larger in comparison to those farther away, while a telephoto lens will make them look closer to the same size.
Sent from my Nexus 7
A wide angle lens acts like a wide angle mirror, like the one on the passengers side of your car. (objects are closer than they appear)
