Winding Highway...
ATVenture
Northern Ontario, Canada
I really liked how this one turned out... but it could obviously have turned out better. Is there anything I could have done different?
Taken with my Canon SL1(100d) and my 55-250mm lens.
thanks everyone!
Umm, is that Hwy 60 going towards Algonquin ... if so, I can't say much since I am biased as that road goes to one of my favourite places in Ontario.
My favorite drive! You are correct. The majority of my photos are within A.P.P. :-)
Nice shot i want to head up to A.P.P sometime have never been there before
I think the composition is very nice, but the vignetting is too heavy handed IMO. I think this might also make a great B+W conversion since the tones are nice, but the colors are pretty muted.
I also took a look at the EXIF data because something didn't quite feel right to me. Here is what it showed ... AUTO 1/640, f10, ISO 800 @ 96mm, Exposure Comp -1/3. For a shot like this, the shutter speed seems really out of whack to me...I'm not sure there is a reason to be so quick with that at the expense of increasing the ISO. Something like 1/200 would give you would allow you to get another stop lower in ISO which might be nice for landscape photos. I shot with an SL1 for a year and found that it does make a difference. Even better would be to pick up a tripod, which would allow you not to have to worry about shutter speed at all.
Anyways, I took a peek at your webpage and you have a great eye for composition. Keep taking those photos and posting!
Thats EXACTLY what I was looking for.. thanks! I had my camera set to AV and manually set it to f10 but for some reason left the ISO at 800 (I was shooting foxes prior to this in lower light). Now I want to recreate this photo but with a lower ISO, probably 200?
Thanks again
Thanks again
For landscape shots, I almost always shoot fully manual. I haven't used the SL1 in awhile, but I know that my Nikon seems to like to increase the shutter speed and ISO more than necessary. Since nothing is moving (usually), you can take your time and use your meter to get the shot you want. At 96mm on the 1.6x crop sensor, you probably want to keep the shutter speed in the 1/125 to 1/200 range hand held. This does limit your options a bit, but if you went to f8 you could probably get close to ISO 200 (although more likely 400).
Side note: you might want to change your profile to allow your photos to be edited. No one here is going to look to steal your photos, and honestly, even a PS hack like me could remove that watermark in a matter of seconds ;). I'm a much better photographer than I was a year ago because of these forums, and much of the reason was because there are many users who can show you different ideas on your photos, or even walk you through different post-processing techniques if you allow us to edit them.
Very nice, but I do agree with JonA-CT that the vignetting is just a bit too much. It initially raised a question in my mind as to why the sky looked a bit strange. I would back it off a bit and maybe lighten it a bit so that it appears to blend better with the sky,
WesternGuy
I think your re-edit is MUCH better with the removal of the vignette! Vignettes are something that I have found should be used in moderation.. Overall I really like the composition in this image. I agree that a lower ISO would probably help as it seems there is quite a bit of noise in the image.
Have you considered cloning out the road sign? I'm torn because on one hand it might make the image more clean, but on the other hand it might remove an item of context from the image. I personally think it might clean the image up which would look better, but that could just be a matter of taste.
Way better without the vignette
Thanks everyone! I really appreciate it! I am going to re post the new version on my sites.
As for the road sign in MY opinion it makes the picture much better and I wanted to include it. I find it not only makes the image look clearer but I find it stands out first and it perfectly describes the highway behind.
