Eclectix
- Joined
- Aug 8, 2013
- Messages
- 209
- Reaction score
- 70
- Location
- Colorado, USA
- Can others edit my Photos
- Photos OK to edit
I tested the 18mm vs 24mm. I can conclude that it's quite the difference. I can get a lot more in the image with the 18mm than the 24mm. Whether or not it would be super useful, I don't know. But I'll bring along with me none the less.-snip-
You can fit more people into frame with an 18mm lens than you could at the same distance from the subjects with a 24mm, but there are more factors than this to consider. For instance, this will also affect how much background falls into the frame- including potentially unsightly objects. It will also most notably cause perspective distortions which are likely to produce unflattering views of your subjects. Also, it will have a greater depth of field, meaning that your background will appear nearly as sharp as your subjects- that coupled with a lack of lighting equipment means that they will blend into the background and produce a very flat looking image. If at all possible it is best to get further from your subjects and use a narrower angle- I would suggest at least 35mm (although 55 to 85 would be even better yet).
You said that you do not plan to get any more equipment except for perhaps an inexpensive telephoto lens, but if you are serious about pursuing this at all then I would at least suggest looking into some basic strobe equipment. You can get a basic starting setup fairly inexpensively- especially when weighed against the cost of travel to China. In my admittedly novice opinion, I think a basic strobe setup will be of much more use to you than a telephoto lens for wedding photography.
And, not to beat a dead horse but I would also echo the general sentiment in this thread; practice every opportunity you get if you are serious about your goal. Some people learn more quickly than others, but not without a lot of study and practice.
