Obviously, I wouldn't be keeping (or using) the kit lens on a pro camera body. Hell, I don't even want to keep or use the kit lens on the D7000. My #1 priority is getting at least 1 quality lens. I might be amatuer, but I'm not stupid. I don't know why you'd assume I'd even attempt using this lens on a D700 or D800. lol
Anyway - thanks. I'm thinking I will buy the D800 regardless and get a few, better lenses.
You don't know why I'd assume you'd use your kit lens on the D800?
Because you didn't mention BUYING any lenses to go with the D800. That's why.
You really need to get your priorities straight. You'd be making a poor decision IMHO. A "pro body" does not a "pro photographer" make.
This is a common misconception among amateurs. They often think, "Why should I stick with my current entry level or mid grade body, when I could buy a PRO BODY OMGLOL and be a PROFESSIONAL PHOTOGRAPHER!?!" I'm
not saying that's you, believe me. But we do get a good flow of threads with that same mindset coming through the forum. They don't take into account the lenses that they want to use, or even know what lenses TO use.
Again, I will reiterate. Unless you're going to be buying some SERIOUS glass with your D800, I'd just stick to buying serious glass rather than a new body. The D800 has a 36mp Full Frame sensor. Photographic technique and high end lenses are both paramount when using that camera. It will most likely make your photos look worse than on the D7k IMHO.
What you're failing to understand is that the guts of the camera are the same. You don't need to "learn photography" on a pro camera body. It's going to expose exactly the same way as on your D7k. The shutter speed and aperture wheels are in the same spot. Cosmetically the cameras are pretty similar. You're not gaining a whole lot by moving to a full frame body, especially if you don't even know WHAT you're gaining.
