Dusmith1
- Joined
- Oct 8, 2016
- Messages
- 22
- Reaction score
- 1
- Can others edit my Photos
- Photos OK to edit
Let me know any truth to this I have read this on many web sites
Canon THIS REVIEW COVERS
Intended Use «
» Weight and Dimensions «
» Handling and Build Quality «
PAGE 2
» Image Quality «
PAGE 3
» Sample Pictures «
» Conclusion «
» Further Information «
TABLE OF CONTENTS
Note: this lens has a predecessor - the Canon EF-S 55-250mm f/4-5.6 IS
The EF-S 55-250mm f/4-5.6 IS II is a very popular lens. Both as a separate buy and in the twin kit edition together with the EF-S 18-55mm f/3.5-5.6 IS II that Canon ship with some of their cameras. It does make a lot of sense to combine the two because together they give you an effective focal range of 29 mm to400 mm which covers just about everything except for the ultra wide angle.
[paste:font size="5"]Intended Use
Wildlife & Sports
At 400 mm effective focal length the EF-S 55-250mm f/4-5.6 IS II is ideal for even smaller wildlife (like birds). And if you'd like to add a little context to the image just zoom out to a minimum of 88 mm. But wildlife and sports photography also require low f-stops to achieve fast shutter speeds. The EF-S 55-250mm f/4-5.6 IS II offers f/4 at the wide end but only f/5.6 at the tele end which is a little slow. At least the excellent image stabilizer helps with slower shutter speeds but of course that can't prevent blur from subject movement.
Portrait
At the wide end the EF-S 55-250mm f/4-5.6 IS II has just the right focal length for nice portrait shots. Again the aperture rating is not excellent but certainly sufficient for this purpose and the large zoom range will even allow closeups from far away.
Intended Use «
PAGE 2
» Image Quality «
PAGE 3
» Sample Pictures «
» Conclusion «
TABLE OF CONTENTS
Wildlife & Sports
Portrait
