BestOfferBuy
- Joined
- May 5, 2011
- Messages
- 589
- Reaction score
- 1
Price: $76.40
- Brand:YongNuo
- Model:YN560
- Brand new digital camera accessory
- Designed for professional photography.
- Elegant, professional design
- Power zoom function in a push of a button (focal length range from 24 to 105mm)
- Improved wireless triggering sensor which makes S1 and S2 mode usable outdoor at a distance of 15 meters.
- Sound indicator: Flash gives a ticking sound when charging is complete (Note: sound indicator can be turned off).
- New charging socket for external power pack (comes with an extra charging socket for external power pack)
- PC synchronized port
- Fast speed charging cycle: YN-560 digital camera accessory only takes 3 seconds to charge even for old batteries (4-5 seconds charging). The external power pack can also be used to accelerate charging speed.
- Supports high-speed continuous shooting: Under output level of 1/8 or below, YN560 can support 8FPS high-speed continuous shooting.
- Improved power saving mode: Flash automatically shuts down when not in use after a period of time.
- Finer output control: Output control ranges from 1/128 to 1/1 and each class of flash output has 8 small fine tuning stalls. With its zooming flash head, YN560 makes you achieve your desired lighting effect.
- Automatic saving setting: YN560 automatically saves your current setting.
- Comes with overheating protection
Parameters:
- Guide number: 58
- Circuit design: IGBT
- Flash mode: M, S1, S2
- Zoom range: 24, 28, 35, 50, 70, 80, 105
- Up/Downward angle :-7~90 degree
- Left/Right angle: 0~270 degree
- Power Source: 4 X AA size batteries (Alkaline or Ni-MH)
- Battery Life:100 - 1500 times (with alkaline batteries)
- Recycle Time: Approximately 3 seconds (with alkaline batteries)
- Color Temperature: 5600K
- Flash Duration:1/200s - 1/20000s
- Flash adjustment: 8 levels of output control (1/1,1/2,1/4,1/8,1/16,1/32,1/64,1/128); 57 levels of fine tuning
- External interface: Hot shoe, PC port and external charging port
- Wireless triggering distance: 20~30m indoor, 10~15m outdoor.
- Size:190*78*60mm
- 1* YN560 Flash Unit
- 1* Flash Stand
- 1* Protector Bag
- 1* English manual (Original Manufacturers Package)
Buy YongNuo YN-560 Hot Shoe Flash Speedlight Wireless, Light Trigger for Canon and Nikon Here
New Products:
LP-E6 Compatible 7.2V 1800mAh Battery for Canon EOS 5D MarkII/TD
Mini Universal Speedlight Soft Box for DSLR
7.2V 1400mAh Rechargeable Lithium Battery for Nikon Digital Camera
Mini Universal Folding Speedlight Soft Box for DSLR
2-Piece Protective Snap-on Hard Screen Protector Covers for Canon 5D
Protective Snap-on Hard Screen Protector Covers for Nikon D7000
Universal Aluminum Alloy Straight Flash Bracket for Camera
camera accessories, camera bags, camera lens, digital camera accessories, camera filters
