Background light
Discussion in 'Beyond the Basics' started by plastii, Mar 31, 2010.
  1. plastii
    plastii TPF Noob!
    Oct 12, 2007
    317
    Gilberts, IL
  2. Derrel
    Derrel Mr. Rain Cloud
    Jul 23, 2009
    40,232
    15,105
    USA
    Position a flash head aimed straight at the background, with the flash's reflector about the mid-back height of the subject, or perhaps very slightly lower. Using a smaller reflector like a 5.5 to 7 inch reflector, with the flash head reasonably close to the background material, you will naturally create a graduated fall-off in the light on the background. Depending on the flash system you may, or may not, need to add a honeycomb grid to the flash head; it kind of depends on the flash.
  3. benhasajeep
    benhasajeep No longer a newbie, moving up!
    May 4, 2006
    4,017
    494
    Also the same effect can be done with Photoshop with a fully lit background.
    Deppends on if you want to do it the traditional way or the digital way. ;)
  4. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    yeah, but the real way always looks better.
  5. plastii
    plastii TPF Noob!
    Oct 12, 2007
    317
    Gilberts, IL
    Thanks for the info - do I have to use flash? Can I use spot light or flood light?
  6. Big Mike
    Dec 16, 2003
    33,872
    1,823
    Edmonton
    No, it doesn't have to be flash...but if you are using flash/strobe as your main light, then it might be more of a challenge to match the exposure and WB of the main/fill lights to the background light.
    If you are using the same type of continuous lights for all your lighting, then it would be easier to balance...but IMO, that is not the best way go about shooting portraits....flash/strobe is much better.
