Depth of field function
Discussion in 'Beyond the Basics' started by Cuervo79, Apr 28, 2004.
  1. Cuervo79
    Cuervo79 Guest
    Hi, I have a Canon EOS 500N (rebel in the US) I use mostly the manual function or the P (when I´m not interested in control) but I've never used the depth of field option, and I´ve lost the manual. could anybody explain it to me? I have 2 zooms a 35-80 4.0-5.6 and a 75-300 4.0-5.6.
    ltrz
  2. markc
    markc TPF Noob!
    Mar 8, 2004
    4,237
    6
    Rochester, NY Velocity: Unknown
    Do you mean setting the aperture (which affects DOF)? You can set it in manual mode, but I usually shoot in aperture-priority (Av) mode and let the camera pick the shutter speed. The smaller the number, the bigger the aperture and the less in focus.
    With a max aperture of only f4.0 (smaller number = bigger aperture), you won't be able to blur the background out much (like you could with f1.8 ). What you see in the viewfinder is it. You can use the DOF preview function to see what it would look like with smaller apertures (more in focus).
  3. cypilk
    cypilk TPF Noob!
    Apr 20, 2004
    155
    san francisco
    wait..changing the aperature changes the depth or something?
  4. cypilk
    cypilk TPF Noob!
    Apr 20, 2004
    155
    san francisco
    and change the focus?..i mean blur and everything? how!!!
  5. Cuervo79
    Cuervo79 Guest
    Well its not exactly what I´m asking, I know how to control the depth of field manualy, thepth of field Cpylk is when you see a photo of a portrait outdoors and the subject is focused but the background isn´t, I know a 4.0 aprerture isn´t all that, but it still kinda workx, what I meant is that in the functions bejind the M and before the Roll rewind ther is a D-field option wich when I read the Elan7 features says that it automatically works it out for you, that is what I mean.... (I´m not sure if it says D-field or not, don´t have my camera here)
  6. markc
    markc TPF Noob!
    Mar 8, 2004
    4,237
    6
    Ah. There's one where you can press the shutter a couple of times so that the camera picks the correct aperture so that both points you focused on are in focus. On the EOS cameras I've had, it's labeled DEP and is on the function dial.
    There is also a DOF preview option that will stop down the aperture so that you can see what you are getting. That seperate and I think enabled with a custom function. I don't have my manual handy at the moment.
  7. drlynn
    drlynn TPF Noob!
    Sep 19, 2003
    722
    In the Basement
    Mark's right. On my Rebel it's labeled A-Dep, and basically you tell it which two points you want to be in focus, and it automatically sets the aperture needed.
    I've never used it, so if you try it out, let us know how well it works.
  8. ksmattfish
    Aug 25, 2003
    7,019
    34
    Lawrence, KS
    depth of field: The distance between the nearest and farthest points in an image that appear in acceptably sharp focus. DOF is controlled by aperture, focal length, and focusing distance. Larger apertures (low f/#) have less DOF than small apertures (higher f/#). A wide angle lens will have more DOF at any given aperture than a longer focal length lens at that same aperture. DOF decreases as camera to subject distance decreases.
    copied from the handy FAQ for newbies at the top of this forum. If you've never heard of DOF then there is all sorts of good stuff for you here:
    http://www.thephotoforum.com/forum/viewtopic.php?t=3362
  9. Cuervo79
    Cuervo79 Guest
    So its just as simple as selecting the A dep function focus both points and shoot? sadly my 500N doesn´t have DOF preview option... anywayz I will be experimenting with it... ltrz
depth of field function
what is function of depth of filed
