Do you burn CDs or DVDs?
Discussion in 'Photography Beginners' Forum' started by roxysmom, Jul 17, 2007.
  1. roxysmom
    roxysmom TPF Noob!
    Apr 14, 2007
    78
    Dayton, Ohio
    I have done a few weddings recently and want to burn the images so I can have them later. I used DVD+R but when I went to a local store to make reprints it would not open. I can see them fine on my own computer. Any suggestions?
    Do most people use CDs over DVDs? I was going to do a CD but it was going to take up 3 so I figured the DVD would be better.
    How do most people manage this process?
  2. DeepSpring
    DeepSpring TPF Noob!
    Jul 12, 2006
    1,451
    Los Angeles
    DVD-R is a more used format.
  3. junray
    junray TPF Noob!
    Jun 21, 2007
    19
    DeepSpring is correct. Coming from a video background, DVD-R is more compatible format.
  4. ScenicBC
    ScenicBC TPF Noob!
    Jul 2, 2007
    13
    Coming from a Computer background I much prefer DVD+Rs. I've burned well over 1,500 discs and found them to be more compatible then DVD-R, with the only downside being 10mb (about 1 RAW file). From a price stand point they are cheaper then CD-Rs as well.
    One other thing to note is I do a bit of Wedding Photography so DVDs are definitely a must when your supplying people with 4 - 6mb JPEGs. I shoot all my photos in RAW then batch encode them with both normal settings, and auto exposure in ACDSee Pro so I'm generally giving away two packed DVDRs one with each method. Cheers.
  5. doenoe
    doenoe TPF Noob!
    Mar 4, 2005
    4,267
    23
    Hoorn, The Netherlands
    I dont know if you shot RAW on the weddings and burned those on a DVD, but maybe the store cant read the RAW files. So that can be a reason why you couldnt open the pics in the store.
    And i also burn DVD+R.
  6. Flash Harry
    Flash Harry TPF Noob!
    Jun 26, 2006
    1,918
    Durham, UK
    I back up to DVD but when getting prints from weddings etc I convert to Jpeg and burn to cd, stores here dont do DVD's for prints as far as I'm aware. H
  7. ksmattfish
    Aug 25, 2003
    7,021
    34
    Lawrence, KS
    I've been using DVD+R ever since I got a DVD burner. No compatibility problems so far.
  8. roxysmom
    roxysmom TPF Noob!
    Apr 14, 2007
    78
    Dayton, Ohio
    I don't shoot RAW yet. I've been taking pictures in large/fine JPEG format and have had no problems.
    I'm wondering if I'm just not coping them right. Someone told me once you have to confirm usage for another computer within the DVD? Does that make sence?
  9. sabbath999
    sabbath999 No longer a newbie, moving up!
    Apr 11, 2007
    2,696
    64
    Missouri
    My guess is that the store's reader was a CD reader and not a DVD reader. The +R and -R thing shouldn't make any difference (I am an IT guy) on a modern DVD reader.
  10. EOS_JD
    EOS_JD TPF Noob!
    Feb 15, 2007
    1,698
    I don't use DVD at all. Too slow, slow, slow.... I much prefer multiple external hard drives. A lot faster, very much smaller (you need over 100D VDs to stare the same as a small 400Gb disk) and they are just much easier to use.
    Sure it's a little more expensive but drive prices have tumbled recently.
    Get good back up software and it's a breeze.
  11. Groupcaptainbonzo
    Groupcaptainbonzo TPF Noob!
    Nov 9, 2006
    463
    Turners Hill, West Sussex, UK.
    Roxy. The store can't read your format. So use either JPEG on the disc or at a push TIFF. DO NOT put them into a "Slideshow" or "presentation". just the basic JPEG 300dpi about A4 max and the store SHOULD have no probs.
    I can't speak for the others, but have never had any problems with DVDs , either + or _ . The best answer is to get a printer and do it yourself. A little more expensive, a little more time consuming... But the "I did that" factor is worth a million.
  12. WDodd
    WDodd TPF Noob!
    Feb 20, 2007
    899
    Amherst (Cleveland), Ohio
    I'm going to second EOS_JD's recommendation. I use a 100GB laptop drive so that I don't have to plug in external power. I made it myself with a external hard drive enclosure and a lot of times its cheaper.
    DVD +R or -R shouldn't be a problem either like most people said. Just make sure wherever you are printing supports DVD.
