error 99
Discussion in 'Photography Equipment & Products' started by bazza, Sep 20, 2007.
  1. bazza
    bazza TPF Noob!
    May 22, 2006
    261
    Wirral, UK.
    Does anybody know how to solve an Error 99 problem on a 350d??
    I have taken over 7000 shots and had my camera just under 1 year but I cannot take any more due to this error.
    I have changed lenses, taken both batteries out and cf card out. After half an hour, replaced them all and it still won't work.
    Any ideas, please...
  2. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    I believe that ERR 99 is a general error code, or it's the lens error code.
    The most common cause seems to be dirty lens contacts. Take off the lens and clean the metal contacts...a pencil eraser does the job well. Make sure the contacts on the camera are clean as well.
  3. bazza
    bazza TPF Noob!
    May 22, 2006
    261
    Wirral, UK.
    Just done that and it still comes up.
    If I keep my finger on the shutter release as I turn it on, it fires off shot after shot until I release it. Then the figure that shows how many shots are left, flashes.. And then the error 99 appears.. Also the cf light stays on.
  4. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    Have you tried a different card?
    From the sounds if it, you may have a faulty card or a problem in that area.
  5. bazza
    bazza TPF Noob!
    May 22, 2006
    261
    Wirral, UK.
    I have 2 cards, tried both..
    Even with the card out it still does the same thing..
    My warrantee ran out 2 months ago too. Typical eh.
  6. bazza
    bazza TPF Noob!
    May 22, 2006
    261
    Wirral, UK.
    Except without the cf light...
  7. bazza
    bazza TPF Noob!
    May 22, 2006
    261
    Wirral, UK.
    Sometimes it shows the battery icon (full) when it freezes. then the error99
  8. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    That does sound weird.
    How about resetting, or reinstalling the firmware?
  9. bazza
    bazza TPF Noob!
    May 22, 2006
    261
    Wirral, UK.
    Sounds like a good idea.. How do you go about doing that?
  10. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    It should be in your manual :er:
    I think you can reset it, via the menu. To reinstall it, I think you may have to download it from Canon and use your PC, via the USB cord, to reinstall it. Maybe check to see if there is an updated firmware version for your camera.
  11. bazza
    bazza TPF Noob!
    May 22, 2006
    261
    Wirral, UK.
    Ah, I can't even get into the menu's..
    Got my manual though, i'll look through it tonight. Meanwhile i'll take the batteries out and leave it overnight. Maybe it'll reset..
    Thanks for all your help, much appreciated...
  12. bazza
    bazza TPF Noob!
    May 22, 2006
    261
    Wirral, UK.
    Just a thought, would humidity cause this type of error???
