First umbrella
Discussion in 'Photography Equipment & Products' started by SlimPaul, Feb 21, 2009.
  1. SlimPaul
    SlimPaul TPF Noob!
    Nov 7, 2008
    437
    Hey,
    I've seen some great photos with the use of umbrella. All I have is an SB-400. Would an umbrella and a wireless transmitter be enough or do I need some external lighting (like in this photo I stumbled across )?
    Thanks, Paul
  2. AlexColeman
    AlexColeman TPF Noob!
    Dec 13, 2008
    1,732
    Not really, the 400 isn't nearly powerful enough. For off camera use, you need atleast and SB-600.
  3. Buckster
    Buckster Been spending a lot of time on here!
    Sep 14, 2009
    6,399
    2,334
    Way up North in Michigan
    It depends on what you want to do with it. A shoot-through umbrella just out of frame will do quite a bit for you, even with a lower-powered flash, depending of course on how far it is from the subject.
  4. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    An umbrella is just a tool. It's a light modifier that makes light softer by increasing the size of the light source.
    And we have all seen some great photos made with the use of soft light.
    Since you already have a flash, HERE is a kit with everything you need. Actually, it's got more than you need. The basics are; a light stand, an umbrella adapter to hold the flash & umbrella and a way to trigger the flash (radio triggers in this case).
  5. IgsEMT
    IgsEMT No longer a newbie, moving up!
    Jul 27, 2009
    2,694
    49
    NYC
    400 is weak, as was noted but depending on you're shooting JUST might be enough (i.e. a bit higher iso to get a bit more out of 400, shoot through umbrella, close up, etc). if you want, PM for more specifics and we'll talk.
    Good Luck
