usayit
- Joined
- Nov 15, 2003
- Messages
- 9,521
- Reaction score
- 347
- Can others edit my Photos
- Photos OK to edit
Both.. it doesn't matter how you get to a proper exposure.
You can do this outside of manual mode pretty easily. I learned right away that my 5D2 likes to underexpose just a little in certain situations. I learned by by shooting in Av mode. I took a bunch of pics, reviewed them, noticed many were a little underexposed in Lightroom, and now I know when I need to dial in a little exposure compensation.When i get a new camera body i have to take some time to test it's metering system to determine what type of "tweaks" i will need to make.
My mom still prefers a stick shift over an automatic transmission in her cars for the same reason many manual shooters give here - "it offers her more control". In reality, it's slower, clumsy, inconvenient and less fuel efficient... but try telling her that.
I'd disagree with that. I prefer using Standard Transmission 95% of the time unless in heavy city traffic when clutching would wear out my ankle.
In reality, a competent driver on a stick is faster, more efficient and with greater control of your engine revs you can increase your fuel economy and save money on brakes as well as extend your engine life. (Also see who's off the line and ahead faster, the Stick or the Auto. With the stick you can reach your powerband quicker and get that extra oomph from each Gear.)
Having said that, I shoot in Av and Tv mostly.
The post below me is also wrong, but I won't waste another post off topic.
A manual tranny is actually more fuel efficient than an automatic one because there is a rigid lock between the engine and transmission (no slip). This is compared to an auto tranny where you have a torque converter where there's constant slip. Although autos with locking torque converters improve efficiency a lot, but these generally only kick in when cruising. Plus, the hydraulic pump for the auto tranny requires power.
Like altitude604 said, they're a lot easier on your brakes too, since you're using the engine to do a majority of the braking. I recently had my tires rotated and was told that I still had 75% on my brake pads, which were changed over 40,000 miles ago.
EDIT:
Actually it's not wrong, but it's a wise choice for you to end it here.
