Ok, so I found an awesome tutorial on Youtube and gave the layering and masking a try!
I shot it with the kit lens at about f8 or so? about a 5 second shutter speed in a really dark room with a piece of black posterboard as the backdrop. I clicked the shutter and then used my external flash (circa 1979 canon flash) to flash from the side.
If you're using a 50mm f1.8, I'm assuming you're using a very wide aperture. You can't do that, because you don't know exactly where the smoke will be. A much larger DOF is better, because if the smoke moves slightly toward or away from the camera, it will still be in focus.
