help with white balance
Discussion in 'Film Discussion and Q & A' started by danielsmith4213, Nov 15, 2009.
  1. danielsmith4213
    danielsmith4213 TPF Noob!
    Aug 28, 2007
    96
    Mudgeeraba, Queensland, Australia
    Hi, I recently bought a Hasselblad 501cm after years of using a canon rebel, I've never really used a film camera before but have a good idea about exposure and composition. My question is, what is the process of getting the correct white balance when shooting with a film camera? Is it the film that determines the white balance or is it the processing method in the darkroom? Hopefully you can help me. Thanks
  2. IgsEMT
    IgsEMT No longer a newbie, moving up!
    Jul 27, 2009
    2,694
    49
    NYC
    If I remember correctly, film is already preset in WB. I was just shooting, and then submiting it to the lab for prints. Lab used to scan the images for me and print them (two for the price of $1.50). Last I recall, from the time of buying a roll --> shooting a wedding --> processing/printing charges, it was about $1/frame.
    MAKE THOSE FRAMES COUNT :thumbup:
  3. Derrel
    Derrel Mr. Rain Cloud
    Jul 23, 2009
    40,514
    15,229
    USA
    Film is typically balanced for daylight and electronic flash, or tungsten illumination. Various filters, either screw-in or gelatin, are used for color correction or light balancing,either over the lens, or over the source of illumination.
    "Most" color film sold is balanced for daylight and electronic flash. Color negative film can be exposed to a reasonably wide variety of differing light sources without "too much" of a problem, while transparency film is much better handled by using the appropriate color correcting filters since the slide is " the image ".
    Kodak and other on-line sources have some nice charts describing the appropriate filtration to balance daylight film to various artificial light sources, and vice versa.
  4. Actor
    Actor TPF Noob!
    Mar 4, 2007
    421
    Ohio
    The quick answer is both!
    Film photographers don't really talk about white balance, rather they talk about color temperature and daylight balance vs. tungsten balanced film. Color temperature refers to the shape of the spectrum of your light source. Balance refers to the sensitivity of film to a certain kind of spectrum.
    Most color film is "daylight balanced," meaning that its sensitivity to red, green and blue light matches the intensity of red, green and blue light as it is found in sunlight. Photographs of subjects illuminated by sunlight and taken with daylight balanced film should be correct. However, photographs of subjects illuminated by tungsten light (e.g., incandescent light bulbs) will have a reddish cast because tungsten light does not have as much blue light as sunlight. This is very noticeable in the skin tones of Caucasian subjects; they appear to have very red skin, as though sunburned. There are three solutions to this problem:
    1. Use flash. Strobe flash units emulate sunlight.
    2. Use a blue filter. I think the filter normally used for this is an 80A. It allows blue light through while attenuating the red and green so the resulting light is close to sunlight. The down side to using an 80A is that it absorbs two stops of light. If you are using an external meter you need to re-rate your film by two stops, e.g., rate ASA 100 as ASA 25. I find the use of the 80A to be problematic because when shooting under tungsten I already don't have a lot of light; the loss of two stops adds to my troubles.
    3. Tell the lab to "correct for tungsten." Take my word for it, this does not make your lab tech happy. They do not like having to re-adjust their equipment. Every time I've done it my prints have come back with a note (sometimes an in person lecture) about flash, filters and tungsten balanced film.
    Ah, tungsten balanced film, which is more sensitive to blue light than to red and green, thus eliminating the need for a blue filter. Shooting tunsten balanced film outdoors under sunlight puts a pronounced blue cast on the print, so you need to use an amber filter, an 85. The 85 only absorbs 2/3 stop of light, usually not a problem in daylight. The down side to tungsten film is:
    1. As far as I know the only tungsten balanced films available today are slide films, and ...
    2. ... these films are very slow.
    The only example of a tungsten balance film that I can think of offhand is Kodak E64T. (E for ektachrome = slide, ASA 64, T for tungsten.) Fuji makes a similar film.
    Just to satisfy the pedants I should mention that tungsten films come in different color temperatures, usually 3200 and 3400 I think. You may need a different filter than the 85 but IMHO the 85 is close enough.
    Another kind of light is fluorescent, which leaves a green cast with daylight film. The FL-D and FL-B filters are used with fluorescent light, the former with daylight film, the latter with tungsten film.
    If you want to be even more precise use a gray card. If your entire roll is exposed under the same light take a shot of the gray card as your first and last exposure on the roll. Or include the gray card in each shot with the intention of cropping it out later. Choose a lab willing to cater to your desires and tell them about the card.
  5. danielsmith4213
    Aug 28, 2007
    96
    Thank you very much for such an in depth answer!
  6. Mike_E
    Jan 26, 2007
    5,327
    266
    Fuji has a film that can be shot indoors or out. It works pretty well.
    If you are using a flash with an indoor film be sure to gel the flash to the color temp of the lighting.
    Grats on the 'Blad BTW ;)
