Ilford SFX Film Question
Discussion in 'Film Discussion and Q & A' started by benjyman345, Apr 17, 2007.
  1. benjyman345
    benjyman345 TPF Noob!
    Sep 26, 2006
    152
    hi,
    I have a roll of Inford SFX 200. I know it is a B&W film with extended sensitivity into the near infrared at 740nm.
    I have never used this film before and was wondering what is the best use for this film? Should I use any filters? I think they suggest red - what strength? Does the in-built camera metre work sufficently for this film or do I need to take into account any exposure errors?
    Also I believe you develop this film in the normal processes in the darkroom? If there is any other information I should know about it please let me know.
    Thanks!
  2. Alpha
    Alpha Troll Extraordinaire
    Mar 15, 2005
    5,454
    41
    San Francisco
    Because the film's sensitivity does not extend all that far into the IR portion of the spectrum, you'll need a darker filter if you want it to produce truly IR-looking shots. If you look at the actual SFX filters made my Ilford, they're very dark, probably akin to a 29 or so. You can shoot it with a lighter filter, like a 25, but you aren't going to see that big of a difference between it and regular b&w film.
    Check out the fact sheet here:
    http://www.ilfordphoto.com/Webfiles/2007321132823302.pdf
  3. Steph
    Steph No longer a newbie, moving up!
    Oct 18, 2006
    1,314
    Steventon, Oxfordshire, UK
    Also, be aware that some cameras use an IR sensor to count frames when advancing the film. This will fog the IR film.
  4. Alpha
    Mar 15, 2005
    5,454
    41
    San Francisco
    Yeah but SFX rolls off around 740nm. There's no way an IR sensor is going to output light at that short a wavelength. I would worry about that, on the other hand, with something like HIE or 820c, but not SFX.
  5. terri
    terri Administrator Staff Member Supporting Member
    Sep 2, 2003
    27,194
    2,765
    In the mental ward of this forum
    I've shot the stuff with my Pentax MZ-S, and the infrared film advance sensor had zero effect with that film.
    I got nice IR effects with a #25, but I would agree if you wanted them more pronounced, a darker red filter will give you that. If all you have is a #25, though, give it a try too.
  6. gizmo2071
    gizmo2071 TPF Noob!
    Oct 19, 2006
    861
    Toronto, ONT
    I'm glad somebody posted about this film.
    I'm about to buy some B&W film and thought I might pick some of this up.
    I think it might pick up a few rolls now to go with the fp4/hp5 I get :D
  7. Steph
    Oct 18, 2006
    1,314
    I stand corrected and I am glad to learn that I can use SFX in my Canon EOS 50E.
  8. benjyman345
    Sep 26, 2006
    152
    I have been unable to find any red filters abover 25a unless I buy an Infrared filter, which blocks all visible light.
    Just a thought.... if I placed two 25a Red filters on top of each other would this work? If so what would it be equivalent too?
    Thanks
  9. Helen B
    Helen B TPF Noob!
    Sep 16, 2007
    3,296
    465
    Hell's Kitchen, New York
    The Wratten 25 (it used to be called the 'A') has a 50% absorption wavelength of 600 nm. At longer wavelengths there is very little absorption, so stacking two of them together won't move the 50% wavelength very much.
    The Wratten 29 has a 50% absorption at 620 nm. The B+W 091 is a 630 nm filter. Both these can be seen through.
    Most people can just see through the B+W 092 (50% @ 695 nm) but very dimly.
    Best,
    Helen
  10. benjyman345
    Sep 26, 2006
    152
    So what filter should I look out for this film?
    I know 25A will be fine but I want something which will enhance the IR a bit more and create a mroe dramatic effect.
    When I search B&W 091 filter I can only find the Cokin P091 Dream Diffuser Filter.
    thanks
  11. Helen B
    Helen B TPF Noob!
    Sep 16, 2007
    3,296
    465
    It's B+W rather than B&W. The Wratten 29 is very close to the 091.
    Best,
    Helen
  12. benjyman345
    Sep 26, 2006
    152
    I have found an R72. (I believe thats a dedicated IR filter)
    Is that overkill?
