Ysarex
- Joined
- Nov 27, 2011
- Messages
- 7,139
- Reaction score
- 3,701
- Location
- St. Louis
- Can others edit my Photos
- Photos OK to edit
So, no field work for 600e? Like I expected... well, in that case I can keep my Lenovo laptop with horrible panel and invest money in good monitor, so I can edit when I'm home...
Just one thing that I don't understand. I see all the time srgb % in laptop previews. It's on notebookchecker.com. So, higher the srbg % is, the colors are going to be produced better, right? Or am I wrong? A lot expencive laptops have just 60-70% of srgb coverage. And I have saw few less expencive with higher srgb coverage. Am I missing something?
You're right. When you see any cost/performance variance that gives you pause stop and ask yourself what is the hardware for. Pro-level photo editing isn't at the bottom of the critical-customer-feature-list for laptop manufacturers -- it's not on the list. They're not made for what you have in mind.
I got it like this, good intel i5 or i7, ram 8-16gb, good gpu, IPS Full HD panel (15" min) with >90% srgb? Or I'm wrong?
You're right. I have a 17" laptop with one of those 60-70% panels that I use exclusively for teaching. (I teach at a couple different campuses and the easiest thing for me to do is bring my own computer and plug into their projection system.) This is a Toshiba. I used to have a MacBook Pro 17" but the Toshiba is better. I do calibrate the laptop screen and every once in awhile if I'm traveling I'll give in to the temptation to edit some recent photos in a motel room.
17" is just way too bleep bleep small for starters. Some of my editing software won't even display properly on a 17" screen.
Because the screen is calibrated I can usually do a fair job with a first run edit on the photos. But because I have the experience of editing with better equipment at home at my desk I immediately start feeling a loss of confidence. When I get home I check what I've done and basically I was heading in the right direction but final readjustments are necessary.
If I had to use a screen like the one on my laptop I'd do what I had to do and make a go of it. I think the results would be fair overall but I'd get the fine nuances wrong.
Joe
