Light pollution removal
pursuer
Canada
I have had a few people ask me about this so I decided to make up a tutorial. I will be using adobe photoshop CS2 but most of this should be relevant for earlier versions as well.
Below is an image of the peiades star cluster taken by doenoe.
Instead of a nice dark sky the background is saturated by light pollution, ay attempt boost the levels of the stars will also amplify the light pollution.
Open the image in PS and duplicate it.
apply a dust and scratches filter just strong enougth to remove all the stars to the copy of the image.
I used a filter with a radius of 16 and a threshold of 7.
This should leave you with just the light pollution.
So right now we hve the original image plus a copy with just the LP.
The next step is remove the isolated LP from the original. There are a few ways to do this but the best is to invert and color burn.
select the origional image and then choose apply image from the menu
The apply image dialog box will appear,
select the copy as the source
set blending to Color Burn
check the box that says invert
hit ok
You should now have and image of just the stars with the LP removed.
Now you can boost the levels to taste and apply a usharp mask, I used 0.5 at 100%
The finished product
origional
Great tute Pursuer! Once again shows there's a million ways to skin a cat.
I did it a slightly more simplified way (for me) by using layers, instead of creating a whole new document. But whatever works best.
I tried the way you explained here on one of my shots and it worked a treat! But it also lost the tree detail in the foreground. Is there any easy way you know of keeping the tree visible?
Thats a tougth one Vicky, I tried using the tree itself as a mask
But I realised the tree is so dark that it just won't show up against the black sky, so the best I cloud come up with is this
I used the same method as above, except I set the opacity to 60% so the sky would not be completely dark. That left me with a slightly redish sky, So I used the hue and saturation dialoge to selectivly edit the reds and setting the lightness to 0. This is new for me, my astro pics never include a foreground.
Is Photoshop CS2 pretty much the same thing as version 7?
bettyB, Its similar. I just upgraded from 7 to CS2 and found that most of the new features are aimed at photograhy rather than web/graphics. More so than recent previous versions. Getting back to what PS was originally for! :)
but if you still have 7, you will be able to get by no probs
