Monopdo under $40?
Discussion in 'Photography Equipment & Products' started by ir0n_ma1den, Jun 19, 2008.
  1. ir0n_ma1den
    ir0n_ma1den TPF Noob!
    Feb 22, 2008
    112
    Centreville, VA
    I will be needing a monopod soon but I don't know what to buy.
    The 2 I have been looking at are the Cannon 100 and the Bogen/Manfrotto 676B (The one that can carry 10lbs).
    I've heard of Bogen and they seem pretty good but I don't know which one to choose or if they are even good.
    thanks
  2. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    Bogen/Manfrotto is a great brand, it's hard to go wrong with that.
    I've got a cheap monopod, I think the brand name is Optex...but it's probably a generic product. The clamp locks aren't as strong as a more expensive pod but the price was about $40.
  3. kundalini
    Jul 18, 2007
    13,608
    1,933
    State of Confusion
    I got the Manfrotto 790B because it folds down to only +15". It states to hold 2.2lbs (1kg), but I have mounted over 5lbs of gear on top several times without any failures. For the extra $2, your choice is probably better.
  4. Mystwalker
    Mystwalker TPF Noob!
    Jan 25, 2008
    544
    I believe Canon's monopod is like $35 - I have this. Am thinking it's a bit flimsy but I only use it to help support 30D + 70-200 so full weight is never on it (unlike tripod).
    Do not believe I've seen a Manfrotto below $50.
  5. tirediron
    Jul 8, 2005
    40,900
    12,419
    Victoria, BC
    Nor have I; the cheapest I've ever seen a [new] one is abut $65, and that's less head. I would second the recommendation for a Bogen/Manfrotto - top notch gear, easy to get parts for (quick release, etc). After all, it doesn't make sense to save a couple of dollars when you are going to support hundreds or thousands of dollars worth of gear!
    Optex is an "offshore" company that brands a whole raft of still and video accessories. Their stuff isn't bad, but IMHO, it's not up to sustained or hard use.
