Polarizing filter for Canon G9
Discussion in 'Photography Equipment & Products' started by gendarmee, Feb 1, 2008.
  1. gendarmee
    gendarmee TPF Noob!
    Dec 30, 2006
    123
    deleted
  2. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    You need THIS adapter, then you can mount 58mm filters. (58mm is also the size of filters that fit the 18-55mm 'kit' lens)
    ND stands for Neutral Density...they basically block some light so that you can use a longer shutter speed (or wider aperture) than you would be able to otherwise.
  3. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    Do be so impatient...you could easily have found that information by searching Google or even the B&H site.
    As I mentioned in the other thread you started...you don't need a macro lens because your camera will focus down to 1cm without any adapters....that's one thing that digi-cams do better than DSLR cameras.
canon g9 polarize filters
canon g9 polarizing filter
canon g9 with filters
