compur
The black part has image in it
This is consistent with shooting above flash sync speed. The faint image in the blacked out portion is
from ambient light.
Thanks for the responses. I didn't purchase any copies of the screwed up pictures, but I took a picture of the negatives:
Since they are also messed up, I'm guessing it's what you said about the sticky shutter. I'll look into that. I appreciate the help!
Here's a picture of the camera as well if anyone cares to check it out:
There are only 3 frames visible in the picture the OP posted, each half black. Each also appear to have had the same shutter speed - that would explain why they are all 'cut off' at the same point.But if it is a flash sync problem explain why every other frame is black? Why are there no clean frame spaces between frames?
Can you post a better pic of the negative strip backlighted please?
So the question is... at what speed is the curtain slit half frame to cause his problem?
