why do my edits suck
Discussion in 'Photography Beginners' Forum' started by peanut170, Sep 15, 2010.
  1. peanut170
    peanut170 TPF Noob!
    Jun 20, 2010
    291
    Vancouver, Washington
    Using elements 8, watch all kinds of tutorials, but cant seem to get a decent edit. not sure if my screen sucks also, but any pointers, or maybe someone can edit and tell me what they did. any helps appreciated.
    [​IMG]
    turtle edit by peanut170, on Flickr
    [​IMG]
    turtle by peanut170, on Flickr
  2. RobNZ
    RobNZ TPF Noob!
    Jan 17, 2010
    543
    New Zealand
    Possibly because your contrast and saturation levels are little too high, I had a quick go on the original and the edit.
    Original played with levels a bit, adjusted the contrast and vibrancy and sharpened (high pass).
    [​IMG]
    edit "edit"
    Lowered contrast and vibrancy/saturation
    [​IMG]
    White balance is off in the edit as well I think.
  3. RobNZ
    RobNZ TPF Noob!
    Jan 17, 2010
    543
    New Zealand
    PS: your edit doesnt suck, to suck it would have to be FUBAR. Its just a little strong, the more you practice the easier it becomes and the better your end results will be :)
  4. PhotoFly
    PhotoFly TPF Noob!
    Sep 13, 2010
    37
    LA
    It would be helpful if you told us steps you used.
  5. peanut170
    peanut170 TPF Noob!
    Jun 20, 2010
    291
    Its been a little since i did this edit, but pretty sure i just did the levels, curves, and some saturation.
  6. PhotoFly
    PhotoFly TPF Noob!
    Sep 13, 2010
    37
    LA
    [​IMG]
    Here are my quick and dirty adjustments.
    1. levels -- I slid the dark slider in a little.
    2. Curves -- adjusted it so the face looked nice (lightened it up)
    3. Curves-- adjusted it to make the whole image dark.
    4. History Brush -- I set the history brush to step #2 and with it set at about 25% I brushed the face back so it looked good again, but the background was still dark from step # 3.
    5. Dodge and Burn -- Just because I can't stop myself from messing with images, I hit the face the the dodge tool (highlights 3%) and lightened up the face generally (maybe a little too much), and hit the eyes, and the cute nose and the hair against the background so it kind of glows. With the dodge tool (shadows 3%) I hit the background a little behind the hair to make the hair stand out more. Then I hit the background at the bottom of the picture to give some value contrast between it and the coat.
    At some point I turned down the saturation of the coat a little.
    Far from perfect, but not too bad for a start and took less time then for me to write about it.
  7. BuS_RiDeR
    BuS_RiDeR No longer a newbie, moving up!
    Oct 29, 2009
    2,356
    83
    Riverview, New Brunswick, Canada.
    My 2 cents... It may be similar to what others have done... But hey...
    Using the Gimp...
    Step #1 Auto WB
    Step #2 Auto Color Enhance
    Step #3 bump the sharpness a bit...
    [​IMG]
  8. supraman215
    supraman215 TPF Noob!
    Oct 25, 2006
    979
    12
    Philadelphia
    Your topic title is what I think every day, and Photo Fly, that edit rocks. just need to figure out how to edit and adjust brightness and contrast in certain areas only, in GIMP. The hardest photo editor in the world to use.
  9. PhotoFly
    PhotoFly TPF Noob!
    Sep 13, 2010
    37
    LA
    Oops. That should read "With the burn tool (shadows 3%) I hit the background a little behind the hair to make the hair stand out more."
  10. Derrel
    Derrel Mr. Rain Cloud
    Jul 23, 2009
    40,261
    15,115
    USA
    This last edit, by willc, looks decent. I think it might be best to try and use a delicate,restrained hand when editing photos. Less is more, easy does it, throttle her back, that type of thing....a little dab'll do ya, you know?
  11. peanut170
    peanut170 TPF Noob!
    Jun 20, 2010
    291
    Well i appreciate the time taken to help me out, gives me some new things to try out. guess practice is just the best way to learn, like everything. Apparently ur only allowed 3 thanks per post cause it dissapeared. So thanks again.
  12. cyngus
    cyngus TPF Noob!
    Sep 7, 2010
    155
    peanut.. i dig your edit.. if willc didnt post his at the last minute i woulda said your photo was tops.. however i would bring out her eyes.. they are too dark and you cant see any color in them.. she has pretty eyes.. let everyone else know that :)
    easy trick to do that.. take both photos.. put them on their own layers.. withe the original photo on top..
    create a layer mask on that top layer and fill it with black
    then with the paint brush tool .. paint white over the childs eyes.. to bring out the original image and make it shine through the new edited photo
    makes sense?
    pm me if you have any questions!
