18-200 lens
arodrigz
Tipton, IN
Hi all, new on here. Just picked up a new T3i and would like to get a 17-55 and 70-200 lens but have to save up a bit. In the meantime, I'm selling the kit lenses 18-55 and 55-250 that came with it and I thought about picking up the 50mm 1.8 and the 18-200. What do you think of that idea?
Also, I'm talking to a guy about his 17-55 lens and might possibly get it. If this goes through, would it be best to keep the 55-250 until I get the cash for the 70-200 or would the 18-200 still be a good idea.
Thanks
Alex
do you know what the difference in focal length is?
you want to sell the 18-55 and pick up a 17-55 to replace it???? these 2 are nearly identical...
and you want to sell the 55-250 and replace that with a 70-200???? the 55-250 has a more powerful zoom....
i don't get your reasoning... unless the lenses you are replacing the kit lenses with, are a lot faster... i.e the kit lens has max a of 4.5f and the lens you want is 2.8f
As far as the 18-55 goes, it is a f/3.5-5.6. The 17-55 is f/2.8 throughout the entire range plus it has USM. I'm indoors a lot in churches and gymnasiums for my kids activities and thought the speed and f/2.8 would do much better.
On the 70-200, it was a suggestion from a photographer friend of mine. The 55-250 is f/4-5.6 whereas the 70-200 I'm thinking about is f/4 all through the range. Also it is IS and USM.
I think both lenses are going to be faster than the kit lenses and going to work out better with less light.
Your unless is correct, as well as better optics
Big diff between the kit lens and L lens optics and build quality
Sent from my iPad using PhotoForum
So back to the question then, I'm trying to come up with enough cash for a 17-55 and then later add the 70-200 f/4 IS but that might take a while. In the meantime, would I be better served with the 50mm f/1.8 and the 18-200mm IS or should I just stick with the kit lenses 18-55 and 55-250 until I can save the money for the others.
Unless your making money on it, but I would probably stay with what you have until moving to the 17-55. The 50-250 will better at the long end than the 18-200, and you will pretty much be gaining convenience only. All the 50 f/1. 8 is cheap enough to get onto if you want to play with a shallow dof
This is like saying "Why buy a BMW when a Hyundai is nearly identical?" :roll:
Don't waste your money on the 18-200mm. Keep what you have until you can buy good lenses.
Thanks for all the responses. I'll probably keep what I have for now but go ahead and add the 50mm.
Yes, good idea. Do not buy the 18-200.
The only reason I had considered it was because my brother-in-law had picked up an 18-200 for his Nikon D90 and loves the lens. But I think it's more of a flexibility thing for him than a matter of quality glass although I heard someone suggest that Nikon's 18-200 is better than canons. I also thought about it as a walk around lens. What would be another option for a good walk around lens for the future with a bit more flexibility than the the 17-55 but better glass than the 18-200 on a T3i?
The 24-105 f/4L. Great image quality and a nice walkaround lens.
I must admit that I would not recommend the 18-200 either, even though I used it for 2 years and liked it. Then I bought a L series lens and saw the difference in image quality. Now I feel all my pictures that I thought were great with that lens are actually not that great... Really bummed me out.
