24-105 and a bellows
johnnywyoming
Have a Canon 50d, and a 24-105 lens. I would like to buy a macro lens but too expensive just now. Can I use the 24-105 on a bellows? I believe that I can get a bellows for under $50 although any recommendations on ones that work well with Canon would be appreciated too.
The lens you have should work with the bellows but I'd be using it around the 30mm mark.
How would you control the aperture on a $50 economy bellows? Are you expecting to find a CPU- and contact-equipped bellows on eBay?
Unless you get one which retains aperture control you won't be able to shoot anything other than wide-open with that lens. Novaflex used to do a bellows that had this. Not cheap...
Other option with a cheap bellows is to use an older lens ( eg a Canon FD etc ) which has manual aperture control on the lens.
