Phazan
- Joined
- Dec 26, 2006
- Messages
- 737
- Reaction score
- 0
- Location
- Bay Area, California
- Can others edit my Photos
- Photos OK to edit
hmmmm, your camera is on also, right?
its back in..maybe the flash is broken or something..i dont understand though...i just changed it earlier today..and now that u said that i do remember the mm's changing when i moved the wide panelHuh?? You pulled the wide panel, and put it all the way back in the flash?? I see it says 14mm on that picutre. Once you pull the wide panel diffuser thing out, it goes to 14mm and doesn't let you adjust the zoom. But then when you put it in, it should go back to normal.. Mine goes back to 24mm
