SoCalTiger said:
No, the doubling only happens when I have both eyes open. I assume what is happening is that my brain is processing the images from both eyes whereas apparently it "masks" the image from one eye in most other people who have one dominant eye? Otherwise, I can't understand how it is physically possible to horizontally line up two objects at different distances using both eyes at the same time.
The test, as I understand it, is to line up two objects which are at different distances with both eyes open and then close one eye to see if it moves.
I think you are over thinking this. Your possible lack of a dominant eye has nothing to do with the whole seeing double thing. I just did the test by holding up 1 finger and I lined it up with the doorframe - vertically (my arm was extended and there was a bit of distance between my finger and the doorframe). This is just a frame of reference. It's marking the spot so that you know where your finger/object is. Then you close one eye. If your finger is still lined up with the doorframe that means that eye is the dominant eye. Now close that eye and open the other one. If your finger doesn't line up with the doorframe - you have a dominant eye.
I'm assuming that if with both eyes your finger lines up with the doorframe then you don't have a dominant eye. I guess the opposite would be true as well. Not really sure though. I do know it's rare not to have a dominant eye.
I'm thinking You can even do it by starting out with one eye closed, extend arm and use finger to line up with something in the distance (like a doorframe). Now close that eye and open the other.
