#1 The tracks are not long enough to take advantage of the vanishing point phenomenon. It is distracting to me. Therefore I would do a camera distortion correction to make them parallel.
#2 I would make the ceiling lines horizontal and vertical not skewed. Sometimes skewed works but it don't work in this one for me.
#3 make the lines vertical and horizontal. This "flaw" is best revealed on the left edge reference line
#4 Crop off the very crooked left window member for a much less distracting composition. Or straighten it out to be vertical. Clone out the word scotch.
#5 Crop off the black thing on the right and the black edge at the bottom. KEEP THE REFLECTION INTACT
#6 The vertical lines again are obviously skewed. as are the horizontal.
Even the most casual and technically disinterested viewer is emotionally impacted by vertical and horizontal lines. If they are off they get an off response or the are right and don't get an off response.
As far as the lighting goes. It is the real world and fine. The last one might need a little tweaking to extract the best result however.
