jwbryson1
- Joined
- Apr 21, 2011
- Messages
- 4,280
- Reaction score
- 949
- Can others edit my Photos
- Photos OK to edit
I am a die hard BBQ fan and have my own smoker in my backyard. :mrgreen: It is what I love to do and I plan to do it for the rest of my life. With Thanksgiving quickly approaching, I thought I would share my secret apple brine recipe that can be used on a whole turkey that you cook indoors in the oven or outdoors in a smoker or other grill of your choice. I prefer to smoke mine outdoors for extra flavor (plus, it gets me out of the house for a few hours...)...
Anyhow, here is the recipe...
[TD="colspan: 2"] Apple Brine For Turkey
[/TD]
[TD="width: 50%"] 2 quarts apple juice
1 pound brown sugar (light or dark)
1 cup Diamond Crystal Kosher Salt
3 quarts cold water
3 oranges, quartered [/TD]
[TD="width: 50%"] 4 ounces fresh ginger, unpeeled and thinly sliced
15 whole cloves
6 bay leaves
6 large garlic cloves, peeled and crushed [/TD]
[TD="width: 100%, colspan: 2"] Substitute 3/4 cup Morton Kosher Salt or 1/2 cup table salt for Diamond Crystal.
Combine apple juice, brown sugar, and salt in a large saucepan. Bring to a boil over high heat, stirring to dissolve. Boil for one minute, remove from heat, let mixture come to room temperature, then refrigerate to 40°F.
In a large non-reactive container, combine the apple juice mixture with the remaining ingredients. When adding the oranges, squeeze each piece to release the juice into the container, then drop in the peel. [/TD]
Put the turkey in the brine breast side down. For this purpose, I use one of those orange Igloo brand 5 gallon water coolers. Place a heavy plate or bowl on top to keep the bird submerged, if necessary, or in my cooler I just screw on the top lid.
Brine the turkey for 24 hours. You may wish to stir the solution 2-3 times during the brining process. I'm not sure if this is necessary or if it actually does anything, but I like to do it anyway.
Since brining does not preserve meat, the turkey and the brine solution must be kept below 40°F throughout the entire brining process. So, keep the whole thing in your refrigerator overnight.
After brining, rinse the turkey thoroughly inside and out, and pat dry with paper towels.
Place on a rack over a rimmed baking sheet and allow to air-dry overnight (8-12 hours) in the refrigerator. This helps create crispy skin during cooking.
Apply a very thin coat of vegetable oil or melted, unsalted butter to the turkey skin.
There is no barbecue seasoning or rub applied to the turkey as part of this recipe.
Cook the turkey until it measures 160-165°F in the breast. Quick Tip: The breast will cook faster than the dark meat (thigh, legs), so in order to make sure you do not overcook the white breast meat or under cook the dark meat, lay a large zip lock bag full of ice on the breast for 30 to 45 minutes before placing in the oven or your smoker. This will chill the breast meat and slow the cooking so it heats at the same rate as the dark meat. It works like a charm!
That is it! Enjoy and brine your turkeys!! You will NOT be sorry!
[/TD]
3 quarts cold water
15 whole cloves
6 bay leaves
