BrieKayee
- Joined
- Aug 14, 2012
- Messages
- 109
- Reaction score
- 22
- Can others edit my Photos
- Photos OK to edit
Thanks
I was actually using my point and shoot Olympus camera when these were taken, so some things are need to be improved. Plus with the second photo, my friend just had the wrong dress for it, so it showed a lot of clevelege.
Shrunken head on the night bus said:Hey, guys, guys! Why the long faces?
I think you should use a slightly longer focal length because her face in the first photo looks a bit too stretched up to me.
If you use a compact camera: just zoom in a bit and take some steps back to get about the same frame with less stretching.
a focal length of 24 or 35mm would be super!
oh wait sorry, compact camera... disregard.
Focal length has nothing to do with this.Wrong! Anything under 50mm can have significant distortion (regardless of sensor size), and if used for portraiture... should be far enough away to minimize the distortion. Even a 50mm will do it if too close.
You can transform a picture taken by a 35mm, 28mm, 24mm etc into a picture of a 50mm or any longer focal length by just cropping.
The more you crop, the more loss of resolution - however, assuming a perfect lens, there is no distortions introduced or removed. At all !
Even a 14mm (or less, but 14mm is kind of the limit of what still makes sense) will still have perfectly straight lines except for lens errors or if its a fisheye.
The issue is PERSPECTIVE, not lens distortion.
To make a portrait, you want to keep a distance of about 5 meters from the subject. A bit less might still work, and a lot more still causes little problems (people will look somewhat flat though). This limits the range of good focal lengths for portrait to 50mm to 135mm, for full body to face only, and all relative to full frame.
The famous 85mm f/1.2 Canon portrait lens, for example, is right in the middle of this.
Nikon also has famous portrait lenses, the AF 105 or 135mm f/2 DC lenses, which are thus a bit more specialized for face portraiture.
