another friend
Corvphotography
VB, VA
havent edited it at all. Was wondering if anyone could help me....Whats the best/easiest way to clean up the white background with photoshop cs4?
Hey there, heres just a quick method i did, which is a 5-min job, but you can go into much more detail with it :)
1. Open image in PS
2. Use a levels adjustment layer and drag your middle slider to the right
3. Mask out the model on your adjustment layer, so the background becomes bleached white
4. Then apply a curves adjustment creating a point in the center of the line and moving it up.
5. Again, mask out the model on the curves layer
You are done :)
p.s i do have an image to show you, however i am new and not quite sure how to upload an image XD
id love to see the image. thanks for the help!! I wish i could help you out with uploading it but idk either.
There we go :) i worked it out :) and like i said, this was a quicky, you can do it with much more accuracy :)
Nice job and welcome to the site!
Here is what I did. I opened the image in Photoshop. I went to "Curves". I took the mouse, grabbed the curves line up near the top, and lifted and moved it to the left a bit, and evaluated the background's whiteness. It took about three seconds to come up with the following look. ie, "One thousand one, one thousand two, one thousand three, there, that looks about right." I do see a bit of off-white in the lower right areas, which could easily be stircken with the magic wand tool and replaced with pure white.
yes thanks guys!! ryan and derrel thanks for the help!!
Here is my take. I like Derrel's for the improved exposure, but it seems overly warm. It could just be a preference thing:
what did you do exactly oldmacman?
Oops, sorry... forgot to include my process. I got there quite a bit differently:
- colour corrected first in LR by tinting into the blue
- corrected the overall exposure by about 1/2 a stop increase
- dodged the background with a big, soft brush in LR with a 3/4 increase to exposure and a small increase to brightness
1. Open image in PS
You are done :)
Ok, so when I open the image and add the adjustment levels layer, it becomes completely black. Is that right? if so, how do i do number 3?
