You can easily make 1 minute exposures without a auto guider, Having one helps but there not needed in the beginning really. When I started out people told me you need to spend 1000s of euros to have any joy at this hobby but I couldnt afford such luxuries like eq6 mounts, auto guiders and fancy filters. So i actually started out with imaging sunspots on the sun using the correct solar filter, imaging the moon and planets. Taking video of the sun, moon and planets I was then able to not have to use a computerized mount. I was using my telescope with DSLR attached using a T2 adapter.
Some programs you will want to use once you get started is.
PIPP ( planetary imaging preprocessor )
AS2 (AutoStakkert)
DeepSkyStacker
Registax 5 and or 6
Stellarium
If you dont have a 16 bit processing software Artweaver free 4 is very basic but enough to get started
I dont know what shops your can order from being from Iraq weather from european market or american market but if you can order from european market
Teleskop-Express: Skywatcher EQ3 Astrofoto Reisemontierung mit Nachführung, Polsucher... this is a very good mount to start with and if you want to add a telescope at a later date it can hold up to 7kg.
Teleskop-Express: AstroTrac 320XAG verbesserte Version mit ST4-Anschluss - Montierung für Astrofotografie if you have a tripod already to drop this onto this is a very portable piece and very powerful unit and have seen great results it takes time to get used to it but its very nice.
Teleskop-Express: iOptron 3300B SkyTracker - Star Tracker Nachführeinheit für Astrofotografie this is similar to the astrotrac if you can use google translate heres a blog telling a little about it
https://www.ursa.fi/blogit/taivas-takapihalla/index.php/testissa-liikkuvan-kuvaajan-seuranta-ioptron
Teleskop-Express: iOptron SmartEQ Pro Goto Montierung - verbesserte Version für Astrofotografie heres the pro version of what you wanted the changes it has are
Metal worm & gears
Guiding Port
Polar Scope included
This is a very nice mount if you respect its pay load, if you ever put a telescope on it a small refractor of maybe 80mm would be fine if using for imaging. The other version you linked I would say you can work with it but It may cause a lot of unwanted stress and difficulty.
Teleskop-Express: Skywatcher EQ3 PRO Synscan GoTo Montierung mit Stativ this here is a great piece like the first one i linked but with goto controller so if you want to pop a telescope on like the ioptron smart eq will locate the stars easily once setup.
If you are new to astronomy setting up a EQ mount may take some time and be a little tricky at first but there is a lot of guides out there, you will most likely need to learn how drift align to get the most out of imaging.
