C&C per req:
1. The exposure is wayyyyyyy out of whack here. You've totally blown his crown and some of the background as well as parts of his fingers. You needed probably two stops of fill light image right to reduce the dynamic range, equalize the exposure and produce a correctly exposed image. When composing/cropping, always avoid cropping little bits of limbs such as the fingers. If you do need to crop limbs, do it boldly, not at or near joints and never laterally.
2. A nice high-key attempt; you're just a little over here; you've blown some of the detail on the white sleeves and shoe soles. The image appears slightly soft, particularily near the eyes, and he could use a little more room image right.
3. Skin tones aren't bad, but you've lost all detail in the whites.
4. A bit cliche IMO, but if the client likes it.. Again, your exposure is off here; you're shooting with a bright backlight and as a result the face is in shadow and the eyes are lifeless. A single speedlight 20 degrees camera right with a diffuser of some sort would have really improved this image. If possible, i would suggest recropping to include all of the basket and removing some of the right side to put the subject slightly off centre.
Overall, not a bad set at all, but you have some serious exposure issues to overcome; all easily dealt with using one or two speedlights and a couple of diffusers and reflectors.
Just my $00.02 worth - your mileage may vary.
~John
