Best results with flatbed scanner
Parptarf
Western Norway
I recently got an old Canoscan 9950f to work. But I'm not really that happy with the scanning sharpness. My negatives are tack sharp, but tge scans are mediocre. Even at 4800dpi.)(tested 150, 300, 600 and 4800)
Any tips? I'm using the Canon's standard negative holders.
Sent from my E5823 using Tapatalk
limr
Moderator
Staff member
Supporting Member
Website
moderndinosaur.wordpress.com
I find I often have to adjust scans using post-processing software.
Are you using just the basic scan settings or are you going into the advanced options? I've had to do quite a bit of tweaking to get better quality scans. I'm not at home right now so I can't tell you off the top of my head what my settings are, but I can check them when I get home. Oh, I use the CanoScan 8800.
OP
Parptarf
Parptarf
Western Norway
I'm using the advanced ones, but unsure what I can do to make it better. Unsharp mask turn out better in photoshop.
Derrel
Mr. Rain Cloud
USA
Website
www.pbase.com
I would not use any in-scanner sharpening, and as you've discovered, do your image sharpening routine in Photoshop.
OP
Parptarf
Parptarf
Western Norway
Changing scanner is out of the question as of now. Unless I can get a better dedicated 35mm scanner for under $100.
gsgary
Chesterfield UK
Website
www.gsgary.smugmug.com
Epson v500
Plustek 7500i
desertrattm2r12
desert edge ca
As I mentioned elsewhere, it took me a year of futzig around to be able to make fine scans. And I had a pro make some scans for me and they were nice enough to let me look over their shoulder at what they were doing. I have an Epson Perfection Photo V500.
SoulfulRecover
TPF Supporters
Supporting Member
Texas
Epson v500
Plustek 7500i
Nice E-Type! Got one that's getting some work done as I type this :D
Im interested in your settings if you don't mind sharing
limr
Moderator
Staff member
Supporting Member
Website
Epson v500
Plustek 7500i
Yup, no problem. I'll be doing some scanning tonight or tomorrow, so I'll take a screen shot.
SoulfulRecover
TPF Supporters
Supporting Member
Texas
Epson v500
Plustek 7500i
you rock! thank you
Buckster
In memoriam
Way up North in Michigan
I use the Canon 8800F scanner, and went looking for the best way to get great scans with it years ago, shortly after I got it. I found the information and the device on the following page to be exactly what I was looking for. Maybe it can help you too.
Link: The Single Channel Variable Height MF Film Holder For Canon 8800F 8600F
This page, in particular, is VERY helpful: Using the Single Channel MF Film Holder for Canon 8800F 8600F 8400F
limr
Moderator
Staff member
Supporting Member
Website
Finally gotten around to doing some color scanning. Here are some settings:
On the advice of Buzz, I'm turning off some of the options for color settings (under Preferences). And I usually keep the histogram open to manage black and white points, and grey points if needed.
We've also started scanning at 2400 instead of 1200 to reduce the grain we see, especially in the skies. It seems to make more of a difference in medium format than in 35, and it certainly takes a lot longer.
