Canon 60D Help
sood1992
India
I'm new to 60D and I've been using Canon 1000D from past 1 year. Okay, so I want to know what can I adjust exposure to - or + on AV mode without pressing the Q button? I used to toggle it using +/- button on 1000D, How to do it on 60D?
Look under 'Exposure compensation' in the user manual.
The wheel in the back controls compensation in Av mode. It locks however, after a certain period of inactivity (I believe equal to the meter timeout). So, half click the shutter to get the meter reading, and then you have a few seconds to adjust compensation with the back wheel.
Read the entire manual before posting questions that are answered in the user manual.
You really need some quality time with your manual. And seeing how Canon manuals suck, I'd probably go for the magic lantern guide or similar for your camera. I believe Ken Rockwell has a writeup page on the 60D too.
The wheel controls exposure compensation in both Av and Tv modes. The wheel lock is electronic and can be disabled in the camera settings. I keep mine off and have never had an issue with accidental setting changes. Now, if only canon provided a way to disable the irritating program dial lock.
Like the other posts say, read the manual. I d/l a PDF version and keep it on my phone for easy reference. In iBooks you can even add bookmarks to useful info.
Chann
there are 60D-specific book out there, such as
I've never had a problem with a 'full' Canon manual. I think they're pretty good actually.
Although just last night, while teaching a DSLR class, I discovered that some of the entry level Rebels only come with a 'basic' manual and only supply the full manual as a PDF on disc. That's disappointing.
But I think the 60D does come with a full manual.
Make sure you have pressed the Unlock button under the big main dial behind the camera.
Then turn the main dial and you should see the exposure compensation indicator moving.
You can't rely on the Q button solely while shooting, that's for sure.
Jaan
