MAMS said:
now you've lost me completely, can you expand on that
Oh... sorry. Are you a Photoshop user? I'm sure you can get this done using other programs too.
They way I would do this (I suspect there are faster, better ways) is to make a new layer of the entire image, so that you actually have two identicle photos, one right on top of the other.
Then, open the layers window. Make the top layer invisable by clicking on the eye. Then select the background layer.
Now, choose IMAGE, then ADJUSTMENTS, then CURVES. Now, adjust the image until the background looks good... I'm thinking it should be deeper tones.
Next, go to the layers window and make the top layer visable again, and the background invisable. Select the top layer. Using the eraser tool set in brush mode at 100% opacity, carefully erase the animals portion of the image. Use a brush just large enough to create a soft edge. Check you work from time to time by making all layers visable.
Well... I bet that's likely to be more than you wanted to know.
I hope you find this helpful.
ANYONE ELSE... please let me know the faster, easier way to do this.
Thanks!
